hemi truck runs 14.02 at 95mph in the 1/4
#112
theres more to it then pulling a wire and removing the swaybar i have told all of you some of the other things that i have done like intake... exhaust ...removing weight spare tire....and other track tricks also perfect air is worth alot the hemis love cold air and letting the motor cool off after each pass with the hood up.... tire pressure... 60 pounds in the front and 24pounds in the rear for 2.01 60ft for each tenth you drop in your 60ft you will lose 2 tenths in the 1/4 mile most dragracers know that...and a track that is at very low altitude could be the differance between a 14.0 and a 14.5 at high altitude and that is true ask anybody the track that i ran the 14.02 is at 320ft altitude wich is very good and the track that im going to run next atco dragway is at sea level the best one can ask for .....also a good driver that can launch the truck is a plus... 40 deg air makes all car and trucks run better .....so you see theres more to it then pulling a wire
#113
http://dodgetruckworld.tenmagazines....cs.ten?u=76594
here you go h777 ,
http://dodgetruckworld.tenmagazines....gs.ten?u=76594
now all your dtw info is on here now.
here you go h777 ,
#114
bighemi789.....how long did it take you to find this old thread??? it's over 1.5 years old........since then i have run 13.71 at 99mph (without spray) and i do have the time slip for that run also several people have seen the run .....for the guys that called b/s on my times.... well there are hand full of hemi trucks running well in the 13s (without spray) on dodge truck world ......i was just the first too do so over a year ago .....and for the guys that thought i was running nitrous to get my times you where wrong.......now i'm deep in the 12s with spray
heres my n/a no juice time slip from over a year ago
