TIME SLIP DATABASE
How do you lauch at the track?
Old 10-10-2011, 03:29 PM
blwn4.8's Avatar
Default How do you lauch at the track?
Post up your method for best times! (prefferably 2wd)
I need to learn learn as i am still a track noob!
Old 10-10-2011, 10:34 PM
blackvmax07's Avatar
id like to know as well cause with my new 3200 converter i dont know where the hell to start
Old 10-10-2011, 10:47 PM
CC05's Avatar
Unless you're dealing with nitrous/boost controllers, stall 'er up and take off on some radials?
Old 10-10-2011, 11:04 PM
blwn4.8's Avatar
i have a 3k stall but if i stall it on Drive itll just spin the tires... i usually put it in second but dont know if thats costing me ET
Old 10-10-2011, 11:09 PM
formerly lamborado (1-12-2012)
BOTLFED_AWD's Avatar
3200 stall, leaving on a hundred shot, cal tracs and MT ET street drag radials, used to do the same with a 3600 stall, cut 1.6 60' this was when it was 2wd. i just stalled it up and went, never had an issue.
Old 10-10-2011, 11:10 PM
Baltimore Whore
Mangled03gmc's Avatar
Are you running on slicks or regular tires?? A 3k verter, reg tires is not going to hook period.. On radials let some air out, do not do a burn out, just spin then over a few times.. Then you need to figure out how much to gas it out of the hole.. Slicks is diff, as you can stall the truck up a little bit.. It is a trial and error deal.. Put the truck in 3rd, let it shift it self..
Old 10-10-2011, 11:11 PM
javzh's Avatar
thats because you need slicks
Old 10-10-2011, 11:38 PM
blwn4.8's Avatar
ive been running on street tires but a buddy of mine ^^^ offered to let me try out his slicks so when i get my new tune im gonna ask if i can givem a shot
Old 10-10-2011, 11:44 PM
CC05's Avatar
...then definitely don't expect a launch worth a damn. It might just be me, hell I don't know. But I've never been able to get a decent 60 ft. on any street tires, even with the lowest pressure possible. Try out those slicks. Whole other animal.
Old 10-10-2011, 11:49 PM
Baltimore Whore
Slicks like to find the weakest links
Quick Reply: How do you lauch at the track?
