how much hp needed to achieve times i want
#21
Laid Back
For quarter mile racing, your truck is actually WAY undergeared with 4.88's and 35" tires...
#22
justin tbh man i couldnt tell ya ive never looked down at the tach as im going through the traps, i would think probably 5800-6k like you said if i had to guess its up there but not screaming at the top of its lungs
i also found out today my shift points are jacked so its making me wonder how much time im losing in that aspect. according to the guy that tuned my truck the 1-2 is set at 6100 and the 2-3 is at 6700. i asked him why and he said "i put the shift points right before it stops making power" clearly if thats the case first gear should have a higher point than the 2-3 with the motor having a lower load...starting to think i might need a new tuner for now the 3rd time
#24
really need to get a video how the suspension unloads but my buddy finally sent me the other video of the best pass of the night. nothin special but did put a few lengths on a healthy b18
track video cammed silverado vs honda civic - YouTube
#25
A nice set of milled 243s are good for 30-40hp based on a little ricer math. I would guess 40hp would be good for 2 tenths on your setup. Your big issue is going to be aerodynamics on the big end. Honestly you are getting out of the hole well enough to hit 14.0. Any extra top end power you can get will be important to beat the air resistance.
#26
i figured i was losing up top having the 78mm tb and a 3.5 vs 4" intake, hopefully with the traction aid and everything itll crack 13s and with the heads hopefully net me 13.7s or better. im really thinking about trying out a different brand converter as ive heard what im running isnt exactly the greatest
