I am the fastest!
#36
Originally Posted by ap2002
have you thought about some 317's for that F.I. setup?? I believe people have tried it and have gotten great results with F.I.
I currently make ~9lbs boost with the 3.2" pulley
If I went to better breathing heads like the 317's it will drop my CR to ? 8.5 ? allowing me to up boost but how would it afftect my DD when not in boost?
Thanks again everyone for the kind words, make the moneys spent feel worthy.
#38
Originally Posted by trever1t
My current heads are supossedly similar to the 243's but chambered so with the flat tops runs a CR of 9.9:1
The heads on an L33 flow the same as 317's as far as I am aware. You certainly won't want less compression. If you get the boost over 10psi you'll be losing alot of the efficiency of that blower. I would run the stock heads and just go to a 3" pulley. From there add some cam.
#39
ok, that clears it up...
#40
What's the trade-off, less low end torque before boost, right?
