I guess I've hit a wall as it sits now...
I'm curious, how much timing do you use in the lower rpm? That is commonly the reason the Procharged trucks aren't as strong coming out is the lack of timing in lower rpm. Is your engine the original at over 200k?
yes to original engine...soon to be 210k on the engine & tranny...
26" DR - yes (best ET)...Cal-Tracs - no
at this point, unless under load, the pinion angle is bad, I see no need in installing them if the slicks cured the spinning and wheel hop...
you know, cablebandit mentioned a few months ago that he wanted to try that, but I don't think we ever tried adding more down low...
Richmond 3.70's...
Richmond 3.70's...
FlowmasterMufflers
11-24-2015 01:00 PM
BCraven1018
11-02-2015 07:18 AM
