I'm HOME! First TNT 2012, NPB 6.6x 8th
Well guys, i'm home from my deployment, so that means the truck has work to do.
Pretty much took 1 degree timing out from last time out, so running 15.5 degrees and 20ish PSI. Tonights goal was getting it leave the line. On the big end, last time out I went 105mph, tonight was 103-104.
Good news is i've never cut a better 60 then 1.56 at this local small track. After 4 passes, the 60's got better each pass with tire pressure and rear shock changes and ended with a new best 60 and nb 8th at 1.50/6.67, no nitrous! She'll get a pill on the 1/4 mile run.![Swing It!](https://www.performancetrucks.net/forums/images/smilies/horny-4.gif)
Changes from last year, new 30" hoosier radial slicks, 1 inch lower in rear, 1" higher up front, new cheap-o front shocks... ow and smaller burnouts.![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
Here's the video clips from the night. Notes; on Boost gauge shot, I jacked up the 2-step that pass,still won the race though on quick turbo Diesel rig! Lightning was a built block setup, KB supercharger, not sure on boost. Honda was, well... loud.
Good times, nothing broke and drove her home!
RST GMC - March18th2012 - YouTube
![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
![](http://i152.photobucket.com/albums/s192/blackhawkawd91/741cd02c.jpg)
![Nunchuk](https://www.performancetrucks.net/forums/images/smilies/karate.gif)
