Into the 12s...
I was previously running Goodyear Fortera HLs in a 285/50R20 and had really good traction with those. I ran consistent 13.70-80 and 1.93 60s before adding the AFR 225s and meth. I just put on a brand new set of General UHPs in 275/45R20, and with less than 500 miles hooked the 1.91 above. This was the first time getting on it (street or track) and didn't know where I'd lose traction, so I didn't push it as hard as I could've...felt like I could've been heavier on the pedal without spinning.
As for launch style, I've tried both progressive pedal and stabbing...stabbing put me at 2.20-30 with spinning so I stuck with a fast progressive pedal from a 2500 rpm brake stand. Seems to be working well and I'll keep experimenting with that til I find the traction loss.
Thanks guys!
Bill, I sincerely doubt that I'll be getting where you are without drag radials. Although, a 50-shot has been suggested by friends...just to give a little more top end. ;^)
Originally Posted by trever1t
Not bad for any ride!
Damn Colby you'll be passing me real soon!
Were only a few tenths different now, amazing since the last time I saw you run you were mid 13's.
I wouldn't think that heads would make such a HUGE difference in a S/C setup, hmm....How many lbs boost you making?
