Launch from the line: brake stall or flash
#21
its always best to experiment, i would think that the heat would take away less than the amount of different stalling high the flooring it would gain over stalling low and floooring it
#22
Banned
1 Post
WELL LAST FRIDAY WHEN WE WENT TO THE TRACK I STALL MINE TO 1000 THEN NAIL IT I PUT A 1.65 60' DOWN ON 30x10.5 SLICK.ALL VERTERS R DIFFERENT BUT IF U HAVE NO TRACKTION PROBLEMS THEN GO AND TRY IT NEXT TIME U GO TO THE TRACK.
THIS IS ALSO THE SAME WASY I PUT A 1.64 60' WITH A 5.3
#23
I hope I get those 60ft's now with my fixed air/fuel............
Hey litreddevil, how was the weather when you ran this #'s?
I can't wait for the winter to come, I know my #'s will change for sure.
#25
5 year bitches!
Originally Posted by BigBlockChev572
Your posts aren't making sense. If you have traction. Brake Stall it as high as it will go and you'll have a hell of a launch.
#26
5 year bitches!
Originally Posted by La Chochita
I launched at 1500 and then floored it at green.
#27
I have tried to stall all there is in a converter. For example in my friend's 4-door(La Charcoal). If I would stall all the verter stall speed, it would launch with a little bug. The best times were stalling like 300 rpms less than the verter's flash point. It feels that it doesen't take that much time to flash. It would quickly jump forward.
Hey Quik, what converter do you have? I've heard that the TCI's work very good from down low flashing.
#28
Originally Posted by Quik
so you leave on green? damm son you must be sleeping and getting **** poor reaction times. i either leave on 2nd yellow or as soon as it see the 3rd light up. by doing this best light on a .500 tree was .505, i used to be very consistant doing that. i once hit a .499 that blew
And trust me, if you try to leave even on the third yellow, you'll still get a red light. Here the third yellow doesen't quickly goes to green. All the lights move down in the same pattern.
#29
11 Second Truck Club
Last Friday I made 1 pass to get my base time. I stalled it to about 2000RPM and got a .005 reaction and 1.83 60'. Next time I run it I am going to try it at 24-2500RPM. From what several guys around here say (chochita, danny) it has worked better.
