TIME SLIP DATABASE
Launching/racing in 4X4?
Old 05-24-2010, 08:12 PM
Jeteys5.3's Avatar
Yep i already had to use 4wd at the track the first time i went, couldn't hook at all in 2wd. I think the track prep sucked
Old 05-31-2010, 05:38 PM
8LugChevy Thunder's Avatar
I have push button in my truck and it will NOT shift out under power for me. If you are gonna run less air in the rear tires it will have alot of drivetrain pressure (rear tires are essentially shorter than the front) I cant believe it will shift. If you were to let off it will shift, which would work on a standard tranny when you shift gears.
Old 05-31-2010, 08:54 PM
Banned
1LOW4X4's Avatar
well i know that when i leave a red light in rainy weather in auto 4x4, I can push 2hi and itll shift back in under power....if that counts for anything.
Old 06-01-2010, 02:04 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Some do and some don't with no correlation to engine output. Mine without a doubt shifts out....if I hit that button just a little to quickly I lose the rear. I let pressure out from all 4.
Old 06-01-2010, 02:43 PM
Bumpers's Avatar
Are there any upgrade tie rods and stuff that are stonger? I need some... Mine bent a tie rod 4wd launching. wich mine also isn't lowered anymore I don't know if that would have anything to do with it. But I'm gunna need a idler and pitman arm before to long cuz they are starting to get some slack in them and I wanna upgrade everything
Old 06-01-2010, 02:55 PM
1989k1500's Avatar
Put new idler and pitman arms on it then do the Cognito supports and Cognito heim tie rods, or at least get the sleeves.
Old 06-01-2010, 03:40 PM
sharpshooter's Avatar
I run the Cognito supports and sleeves.
Old 06-01-2010, 08:46 PM
Bumpers's Avatar
Yea I'm gunna do moog pitman and idler with the cognito supports when I do them... I'm gunna look into the heim tie rods to
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
AdaMax
05-16-2016 11:35 PM
turbo6c3
10-05-2015 06:11 PM
slimchevy2
10-04-2015 08:02 PM
StrokeTheLS
09-29-2015 08:33 PM
Quick Reply: Launching/racing in 4X4?
