launching technique?
how r u guys launching ur trucks? do u flash the converter or stall at high as possible and then hit it? whats the most common? whats resulted in the best 60ft?let my know ur opinions thanks guys
I've raced alot of different setups in trucks and cars. I've found that if you have a high enough stall you will get roughly the same 60' from going off idle as you will from pre-loading. Going off idle tends to get a better trap speed though. Pre-loading is only good if your suspension works with that (alot of power applied before weight transfer happens). If you're a bit low on converter stall, pre-loading works out well.
