TIME SLIP DATABASE
A Little disapointed
Old 05-15-2010 | 02:03 PM
  #21
AndysC3's Avatar
Its a vinyl cover so it only weighs about 20-30#. There is a gas station about 2 miles from my house that sells 100. The track is only 7 miles.
Its was 80* and my air intake temp was 95+ and I get around 2-3* of knock retard. If I mix the 91 and 100 I dont get any knock.
Old 05-15-2010 | 08:18 PM
  #22
454navyss's Avatar
Originally Posted by AndysC3
How much does your truck weigh? Mine weighed in at 5200. Im going to install some 4.56 with a eaton trutrac so that should really help me get off the line, along with my performabuilt trans and 2800 TC thats still on layaway. I just have to wait to get back from my upcoming deployment.
5200 and some change with me in it
Old 05-15-2010 | 08:24 PM
  #23
AndysC3's Avatar
It may be the elevation and heat. My runs were between 65-80. elevation is 3000 with a da of around 5100-5200. found a correction calculator for da and it should be at 14.6
Old 06-29-2010 | 10:33 AM
  #24
AndysC3's Avatar
would anyone care to guess how much time I could take off with the Performabuilt Level 3 trans and 2800 TC?
Old 06-29-2010 | 11:21 AM
  #25
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Your times sound right on IMO. I ran a 15.1@89 back in the day with a 5.3 tune, exhaust and 3K stall. A converter will help you a lot. Dont the C3s come with 4.10s? If so I wouldnt bother changing them for the price its going to cost you for both differentials.
Old 06-29-2010 | 12:15 PM
  #26
walledition's Avatar
elevation has a lot to say, im at 6930 feet and with all my mods + 150 shot i run 9.53 in 1/8 mile
Old 06-29-2010 | 12:28 PM
  #27
skoal bandit's Avatar
i'm thinking the times are rather slow for a 6.0...i have a crew cab 5.3 without headers and running 15.2
Old 07-03-2010 | 09:37 AM
  #28
AndysC3's Avatar
C3s came with 3.73 and the 02+ Denali had 4.10. Car and driver had an artical on the C3 and staited that it will run a 15.7 sec 1/4 stock. Hopefully by Jan/Feb I will have my trans, WCCH heads, and cam installed. And have an in person tune done.
Old 07-27-2010 | 06:14 PM
  #29
AndysC3's Avatar
Been reading around the forum about CR. My lq4 has a cr of about 9.4. I'm going to get a set of CNCd heads anyway so I was wondering would it be worth getting the ls6
(243) heads to get the cr to about 10.1. How would that affect boost? only planning on running 6-7 psi untill I can get a forged motor installed.
Old 07-27-2010 | 08:46 PM
  #30
custm2500's Avatar
Ph.D. in HUBRIS
The stall will take .5 or better off your 1/4 also with firmer shifts from an upgraded trans you might shave another thenth or two.
dgreer30
11-03-2013 10:48 PM
patofdzb
11-01-2012 07:58 PM
chevybuilder383
62
10-31-2012 09:32 PM
Scott Mills
05-26-2006 08:41 AM
Ram4Pick
03-20-2003 04:36 PM
