TIME SLIP DATABASE
A little drag racing tip for you STS guys with EFILive or HPT
Old 10-07-2006, 04:22 PM
  #21
kbracing96's Avatar
Originally Posted by vanillagorilla
Were you using your meth on those runs? I'm wondering if there's anyway to fatten up the meth on the starting line to help spool the turbo as well. Hmm...
I was, I could probably set up a switch to run the meth on full during staging, but that would be kind of a pain, but Dusty's idea of use PE to add fuel in the "stall" area sounds like a good idea to me. Maybe 10:1 in the 1500-3000 range?? I will have to give it a try.
Old 10-08-2006, 08:33 AM
  #22
How do I change this text
Wilde Racing's Avatar
I go pretty fat in A/F, while "stalling" mine is alwas 10:1, it is a bit of an art to get the timming of the P.E to stop adding fuel the second you launch....... I'll post up a screen shot of mu P.E table and a scan of a 8 psi of boost stall with a stock converter.......
Old 10-08-2006, 09:01 AM
  #23
9 Second Club
cablebandit's Avatar
add timing on an auto to help spool. If not it will make it lazy on the launch. Quicksilverado has gone 1.65/1.68 (i forget which and I was driving ) and thats with no timing reduction. I will add more next time out. His truck did this on a art car 2800 stall with 2 step. I found this to be true on my own f-body...stick likes low timing to stall....auto HIGH timing...much more than you would think
Old 10-08-2006, 08:24 PM
  #24
jcfreak's Avatar
You could also command PE to come in sooner. I have cut 1.65 60fts on a reflashed stock stall at 2500rpm. I have a 2800 Precision now. I left friday night at 2400 on it and ran a 1.74 60ft. Track couldn't handle the 653tq or my tires and suspension couldn't.
Old 10-09-2006, 02:20 PM
  #25
vanillagorilla's Avatar
Yeah, using the PE does sound like a good idea, even for me. My *** is too cheap to justify spending $265 on a 2 step, so if I could just add enough fuel while reving, I might be able to get a few psi. I'm sure the engine will sound like its drowning though. I could actually use the VE table to faten it up since I'm basically reving in neutral while at the starting line. That way when I yank the clutch to launch, I'd be in a completly different cells. I could do the same with timing too. Hmm...
Old 10-09-2006, 08:52 PM
  #26
I have tried this. I think it will work with the spark, I've not done that yet, but My engine did not like seeing A huge section of the V.E table raised. Normal driving I hit a large section of V.E cells (75 KPA x 5600rpm) But the is a huge section that could be used for brake stalling (100 KPA x 210 KPA x 2800 rpm (or what ever your desiered stall speed) The problem I had was getting to that 100 kpa without rolling...
So I did this
I had the problem of building boost, I could brake stall and only build like 1 or 2 psi, or about 85-95 KPA, I was only reving up to 1800 ish rpm.
I set my P.E table to 1.0 acroos the board. Retuned the B.E table and V.E so that I was free of the P.E table for tunning. Now I did have a bit more tip in K.R, but it all went away once I retuned the P.E. I also had to lower my P.E enable threshold down way low I also would have to lower my MAP threshold.
This is my P.E enable set up.
MAP at 60 kpa
Map hyst at 5 kpa
Delay Torque at 0
Enable torque at 0
Torque hyst at 0
P.E enable TPS (cold)I set the at 30% from 0 to 1200, then 20% from 1600 to 7200.
I plaid with the enrich ment rate quit a bit, but It still needs more. here is a screen shot.
So how did it work??
Here are a few screen shots of a stock 4l80e converter stalling up to 2800 rpm. now If you look at my wideband you will see It's at 10:1, which is were I want it, until I release the brake. Then I want it to go to 11.5:1 ASAP! I still need to work on that and yes That little bump in the RPM and Speed in the first screen shot, is my nasty 4wheel hope launch. I hit 42, then it drops down to 34 mph. lol
Old 10-10-2006, 10:14 AM
  #27
I played with it last night and I was pleasantly surprised. I was able to build a fair amount of boost in neutral. I didn't write a tune or anything, but playing with the tune via the scanner netted me 4-5psi at 4500rpm. Again, this is in neutral (or in gear with clutch in) without a boost controller and NO load on the engine. I commanded an 8:1 AFR and had the timing set to 0*. It ran surprisingly well for being so rich, but it obviously didn't want to idle.
For us few manual turbo guys this might be a good option, especially if you don't want to spend money on a glorified rev limiter. Or if you are using a 2 step then full boost would be easy. I'm going to see if I can't alter my VE table and main spark table from 2000-4500 rpm in the neutral rev cells to replicate the results. It will be a track only tune though.
BKnBLK05
12-28-2015 08:52 PM
Go5.3tt06
09-12-2015 09:29 AM
Austino
07-30-2015 03:28 PM
KOOKS Headers
07-27-2015 01:43 PM
fillpot
07-26-2015 07:21 PM
Quick Reply: A little drag racing tip for you STS guys with EFILive or HPT
