Looking for advice to improve my 60ft times
Hey guys, I'm planning to go to TnT on Friday night and I'm looking to improve my 60ft times. My truck is a 2010 Sierra Denali CCSB AWD. I have a Whipple kit with Kooks 1-7/8" LT's, Volant CAI, and a QTP E/cutout that I only use for the track. Everything else is stock with 3.48 rear (I think?).
My best 60ft time (last fall with just the supercharger kit) was 1.92. I have since been out one other time and I still hover between high 1.9 and around 2.1 seconds. I have tried a few different techniques but haven't had much luck improving those times. They have varied from just launching off idle to launches at about 1,900rpm. I have been hesitant to go much higher because i tried going to 2,500 rpm and Had quite a bit of spinning. I'm not sure that I will be able get better with this truck unless I go for a new converter and/or gears. I have been knocking on 12's for a good while now and I know that if I can get a 1.8 60ft that I will be there (without DA conversion).
I'm not looking to make major weight reductions or anything else to get 12's. I'm pretty proud that I run my truck exactly as its run on the street.
Anyone have any suggestions for me? Did I give up higher RPM launches too early? Is it better to have some spinning with a higher RPM launch than with a lower RPM launch and no slip? Im an old manual transmission guy. I don't have much knowledge on flashing converters and what stall speeds work best.
Some have already said it you desperately need a converter. You will run solid 12 possibly low if the charger likes it enough. Obviously the other part of the equation is getting it to hook. Like I said 12s are in the bag if you get a converter but then you will need a tire to hook. You can find a street tire that you can drive every day that should hook with a full weight truck.
Cool, I will look into DR's when I get a new converter which will likely be this fall. In the mean time, I guess I'll just keep working on finding a good RPM to launch. It's supposed to be in the high 90's tomorrow so I'm all but certain to be stuck in the 13's but I will still go to see if I can improve my 60ft's.
I know it's not the right section, but do you guys have a stall recommendation for a good street/strip converter? This is my DD and I want to keep it street/highway friendly. Obviously this is with the 6 speed.
