MT ET Radial: 255/50s: PSI
How many lbs. in the ET Street, 255/50s do I need? I'll experiment tomorrow, but I thought someone might be able to give me a 'ball' park answer.
Thank you.
Thank you.
Banned
1 Post
16 to 20 is what i ran in mine the more air you can run the better you will be.i would start @ 20 and go from their but the track has alot to do with how you will hook.if they perp the track good then u should be able to run 20+.
thanks , im still smiling about it . i ran 15.1 in 51 degree weather with a 2.2 . now im back with nothing different in hotter weather and the same 60 foot and ran 2 tenths faster . anyways yall are a lot inspiration . the only other true builder ive seen out there with a nbs silverado would be scream , which is a bad truck . but at least were gettin a lot more coming out
