TIME SLIP DATABASE
NA stock block hemi runs 12.88@107
Old 04-23-2007, 07:29 AM
  #21
PlatinumHemi's Avatar
Secret 50 Shot.
LOL
Im going to call BS on gaining 6mph with dropping a little weight and some heads
Seems like you don't have the full story.
Here it is from DT:
OK, here is my best run of the day and also a slip showing how much my truck weighs with me in it.
Alright, I'll lay all my cards out. Some of you seem to think I changed my cam out In my opinion, you don't need a big ole cam to get a 4500 lbs truck down the 1/4 mile. Torque is what we need. I told Marty (at KRC Performance) when I ordered my cam that I wanted a big torque cam. This is the cam he grinded me.
After running that cam for a couple of weeks I noticed monster torque off the line in turn for some loss of high end horsepower. It really lacked pulling power in 3rd gear and felt like stock. Thats when I turned to Stu and Scott at The Hemi Shop. I explained my situation to them and they recommeded their prototype Big Valve Heads. After installing the Hemi Shop Big Valve Heads 3rd gear power was back and way stronger than before.
Here is a pic of the Hemi Shop Big Valve Heads with Manley Severe Duty Pro Flow Valves
After some tuning with the Split Second PSC1-003, I took her to the track for the first time on 31 Mar 07 at Mopar Madness (VMP)
This was my best run that day.
I agree that my MPH does not match my ET. Not sure why that is. Here is another slip from that same day showing a lower ET and higher MPH.
Today I ran at MIR and changed a couple of things which made my truck .36 seconds faster.
Lost 180 lbs
Dropped the Tonneau
Dropped the exhaust after the Y-Pipe
Alternator Kill Switch
Hurst Line Lock
Set Nitto 555r to 18 psi
Adjusted The Caltraks
Installed ATI Super Dampner
Turned O/D Off
A/F was 12.1 at WOT in 3rd and I'm still shifting into 4th before the traps. Gonna lean her out a little and figure out a way to hold 3rd a little longer. I'm gonna try something out this week and see if it works.I'll be looking for the 12.5 ET.
Goes to show you, tons of low end torque got my truck into the 12s, not a bunch of high end horsepower.
PH
__________________
12.88 ET @ 107 MPH N/A @ 4480 lbs
Mods:
The Hemi Shop Heads
Manley Springs, Rods and Titanium Retainers
Manley Severe Duty Pro-flow Valves (2.02" Intake / 1.57" Exhaust)
KRC-210 Custom Grind
Dual 4" Ram Air
E-Fan
Dynatech Headers w/ Dual DMH Cut-Outs after Collectors
Aero Turbine AT3030XL
180 Deg Thermostat
ATI Super Dampner
5/5.5 Custom Suspension Drop
20x8 Boss 304's on General Grabber UHP's for the Street
26" Tall Front Tires on 17x8 OEM Aluminum Rims
26" Tall Rear Tires on 17x8 OEM Aluminum Rims (Nitto 555 DR's)
Caltracs
Stock 3.92 Gears with Limited Slip
Edge 2800 Stall
Transgo Shift Kit w/ Resistor
Hurst Line Lock
Superchips in Performance
And a whole bunch more............
Old 04-23-2007, 07:33 AM
  #22
By the way, I eat SRT-10s for breakfast.
PH
Old 04-23-2007, 08:11 AM
  #23
11 Second Truck Club
bluecajun5.3's Avatar
Default check out this...
N/A 5.7L
Old 04-23-2007, 08:21 AM
  #24
rgvsierra's Avatar
never seen that white truck before, 12.2 was his time? member here?
sweet take off, wonder what 60ft that was..
Old 04-23-2007, 08:22 AM
  #25
ap2002's Avatar
Originally Posted by Brian@JPA
LMMFAO....I dont even waste my time with the Hemi's.....I go right after the SRT-10's
you beat me to it...
Old 04-23-2007, 08:23 AM
  #26
ap2002's Avatar
Originally Posted by rgvsierra
thats seems good, more comp the better,
wait till these new 07 singlecab gm's start coming out more and more, i'll bet they will be in the 12's with no cam or heads. with the possibility to hit low 12's n/a.
i also believe this... those 07's that yall have in the valley are running damn strong....
Old 04-23-2007, 08:27 AM
  #27
ap2002's Avatar
by the way nice times on the HEMI...
I think what is throwing all of us out is the 107mph?
pretty nice cam specs too..
Old 04-23-2007, 08:32 AM
  #28
yes you have. it's amy's truck. she hasn't been on here since 04.
don't know about this pass but it's been a best of 1.62 i believe.
Old 04-23-2007, 08:37 AM
  #29
Sport Side's Avatar
Originally Posted by rdhemi345
I will run equal times to bluecajun.
Yeah, me too. hehehe
Old 04-23-2007, 11:25 AM
  #30
rgvsierra's Avatar
me 3?
i musta overread the 107 part, thats actually quite fast, my truck with weight reduction moves me up about 1mph. lucky you for getting 7.
Quick Reply: NA stock block hemi runs 12.88@107
