neutral or in gear after run?
Yeah,no on neutral while rollin unless in emergency.Iirc the rear planetaries lose lubrication along with free spinning 3rd gear apply clutches.I grenaded a rmvb th350 using neutral after a run.Well actually my buddy who bought the car did but,he only did it cause thats how I drove it.The failure was quite catastrophic imo...
unless you can disconnect the drive shaft at the same time. its horrible to be in neutral or any gear with out the engine running and the truck moving. the pump is ran buy the torque converter spinning. now if you could get your t-case (if 4wd) into neutral then kill it you'd be OK.
