New best 11.27@120
Thanks everyone, I could not get the smile off my face after I saw the times ![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
Here's the vid of that run
![](http://i217.photobucket.com/albums/cc22/thunder550/MiscCrap/th_MVI_2293.jpg)
So I'm thinking that a 10 second pass is definitely a possibility. I picked up over .5 seconds by going from 10 psi to 13 psi, then another .5 seconds from 13 to 15 psi. The more boost I push, the more efficient the turbo seems to get. I think if I can make a pass at 18 psi I will definitely be able to pull a high 10.![Burnout](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_burnout.gif)
Yessir!
Nope! Boost only.
Yeah, next time I go out I'm going to get the tune dialed in for 18 psi running in 1st and 2nd gear, then I'll have to let out. Once the tune is nailed down, I'm gonna go for a glory run! After that, I don't care....I'll try and get it consisten in the 12's or something for bracket racing.
Come on, you know you wanna spray a 100 or 125 shot!!
You can do it. More spray!!
Yessir!
Nope! Boost only.
