TIME SLIP DATABASE
New best time
Old 10-02-2011, 01:56 PM
vicalma03's Avatar
Good times! Hope its something small! Definitely has more left in it!
Old 10-02-2011, 03:17 PM
Mod with training wheels
smokeshow's Avatar
Originally Posted by 53RUSSELL
It was a so called car show and the risers showed up in full force. The DJ sucked.
But hey, the 100 dudes in the crowd were enjoying the 3 hoochies on stage.
I do still think it has an 11 in it, long as I can keep all eight cylinders in the game lol. It felt really strong, no complaints from the trans or rear end/suspension. I may try to nail down that 11 second slip, but this truck has reached its prime. The next project can't come soon enough
Old 10-02-2011, 03:19 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
You should be using a non-projected tip spark plug at your power levels.
Old 10-02-2011, 03:20 PM
smokeshow's Avatar
Link?
Old 10-02-2011, 03:33 PM
NGK BR7EF (or part #3346) is one heat range colder than the TR6, and it's non-projected.
You're trying to prevent the strap on the spark plug from turning red-hot and becoming a "glow plug", because that causes the fuel charge to ignite (pre-detonate) too soon. That pre-det will blow the strap off the plug, and can even blow a hole in a piston.
Also, looking again at your plugs, you're running too rich.
Old 10-02-2011, 04:11 PM
RandTx's Avatar
Nice pass
Old 10-02-2011, 04:41 PM
11 Second Truck Club
fastrt's Avatar
I agree! nice pass for 7 cylinders. you should look into br7ef or br8ef depending on how much boost.
Just fyi, I run br7ef n/a. I will swap in br8ef for 150-200 shot. my motor did not like a projected plug with the qinch I am running.
Old 10-02-2011, 04:51 PM
crazyjay2101's Avatar
Good run for seven cylinders
Old 10-02-2011, 06:02 PM
milkey57's Avatar
Hope the truck is ok..Cant wait to see what all 8 do
Old 10-02-2011, 06:03 PM
99ta's Avatar
What head gaskets and studs/bolts are you running?
Quick Reply: New best time
