New best time...6.45 1/8th w/1.43 60ft.
#24
Man, that damn truck is moving! Looks like your truck is a going against the grain running a 4L65E successfully. What race weight?
#26
What QA1's are you running in the rear? What setting did you wind up putting them on? How do you have the cal-tracs set? I've been reading that you should set them up with a nickel's worth of clearance between the contact bolt and the leaf. I'm not sure if this works on trucks though.
#27
Nice times! You should have easy 9's there when you hit that 2nd shot, maybe even with the 1st shot if you can get into it 10' sooner. I just watched your videos, can't believe I didn't come across them before. That looks like a neat track with all the trees. It will be interesting how long that 4L60 holds into the 9's What is your race weight? Is that a vette 427 worked over or is it a LSX build up?
