New Mudder Fuggin BEST for the HD!!
#24
Adkoonerstrator
It actually did it on the next run also. It might be some of the rev limiter tables/accel modifier tables kicking in. Will check.
#25
Adkoonerstrator
Good runs BTW...
I am not sure what your tune looks like or if it has the parameters similar to the older PCMs, but you might check out this link to help with your lean/knock problem at tip in and your lean problem when you let off the gas... Check out Justin's post #6
http://forum.efilive.com/showthread....ighlight=b3643
