new times
new times
went to monore (twin city dragway) and hopeing for some better times. last time i went my best was a 13.51 @ 97.99. this time was different for sure - 1st run was a 13.50, 2nd run was 13.40, 3rd run was 13.44 little tire spin, 4th was 13.62 with alot of tire spin 2.01 60', and finally after a Top Fuel burnout i went 1.91 60' and 13.36 at 99.75!!!!!!!! only thing different this time was i have a rollpan now. all passes except the last one were made with 20's up front and stock 16"s with 28x11.5x16 MT ET streets out back, and tailgate on. last and fastest pass was made with the same tires and wheels front and back and i removed the tailgate. these tires seem to work better with 11.5#s of air and i only had 10 in them so it probably would have been a little faster off the line with the right air pressure. i finally figured out my 3rd gear problem and most of it is comming from the LS1 intake it stops pulling as hard above 5200 or 5300 in every gear and the converter is still falling 2000 between shifts. so after i fix them and add a underdrive pulley i should be able to hit a 12 in this heat. by the way is was 87* outside with around 45% - 50% humidity.
kr1s
08-24-2015 05:34 PM
smokeshow
08-23-2015 08:23 PM
therock
08-23-2015 01:37 PM
