Yeah baby! 10.69 @ 125.14 time to change your sig!
What did you use to mount the camera?
Thanks! There is a place in the back of the cab in the center that I believe is for hooking a baby carrier. I fashioned a bracket to bolt there and used a suction cup on the back glass to make it steady. I thought it worked pretty good.
frt suspension is way too loose for my taste IMO. good loose lift but not stiff enough compression imo. sick times! 28X10 hooser slicks on a 10" wide wheel should plant that beast with your suspension setup
off subject but what pinion angle are you runnin?
I agree with you on the compression rate. I was going to tighten it up when I got to the strip but forgot my ratio table. At rest the pinion angle is 4* down and with the Caltracs preloaded.
