NEw TIMES AGAIN 12.2 ON THE XCAB
FormerVendor
Congrats on the 12.2 today (DA was 1400 ft when he made that pass). Truck suprised alot of guys with cars with alot of work running similar times and couldnt believe a big truck would run those times on the motor with a 6.0. Glad I could help make a few small tweaks to help pickup that last couple tenths.
My suggested changes if you want to throw some $ at it for the 11's:
-Yella Terra Ultralight Shaft non-adj 1.7 rockers
-4.30 gear /w Truetrac (if I can talk you into them over the 4.10 gear change).Right now you are going through traps at about 5000rpm in 3rd with 3.73 gears. 4.10's will move it up to about 5400 through traps, 4.30 would be 5675. 4.30's would be 6500 rpm @ 125 through traps. in case you decide to spray it 150 rwhp or so...perfect.
-Build the 4l60e with some good parts and send converter back and move up to a SS4000.
-Lightweight driver mod (Call albert)
That alone with a few more passes will probably do it.
kr1s
08-24-2015 05:34 PM
smokeshow
08-23-2015 08:23 PM
Codog
08-16-2015 08:23 PM
