TIME SLIP DATABASE
Procharged times....
Old 06-26-2010, 11:33 AM
chevyridinhigh22's Avatar
Default Procharged times....
Im pretty sure this truck should be faster... I have all mods in sig, 3.42 gears, 275.45.20s streets...
This is my fastest run out of 14 runs...
r/t .070
60' 2.289
330 6.0.10
1/8 8.969 mph 84.61
1000 11.479
1/4 13.657
All other runs where 13.7s What do yall think?
Old 06-26-2010, 02:01 PM
sureshot's Avatar
Do you have a stall? Your 60's are horrible. If you get your 60's down, you will see much better results.
Old 06-26-2010, 02:06 PM
Baltimore Whore
Mangled03gmc's Avatar
3.42's is killing you, what converter you running??
Old 06-26-2010, 02:11 PM
Stock stall... It's a dog off the line. And it died on me after every time I would clean the tires off...
Old 06-26-2010, 02:33 PM
sureshot's Avatar
Get a stall and like Mangled said, change your gears. I think you'll see a huge improvement!
Old 06-26-2010, 02:39 PM
Baltimore Whore
You def need to stall it, atleast 3k. Prochargers like them the more the better. Mine loves the 3200, 410's, next time round I am going to a 36 or 3800.. You have to remember centri blowers are nothing more then a belt driven turbo, so they like rpms. The more you feed them the more they eat
Old 06-26-2010, 02:54 PM
Ya, im getting a stall for it, I just expected better times with it...
Old 06-26-2010, 04:27 PM
DAYTONA81's Avatar
yeah i saw you last night. I would expect more more out of your set up......stall or not withall those mods low 13s would be slow for you...i would figure high 12's.
Old 06-26-2010, 04:55 PM
Ya, I dont know whats going on... Everytime after I would hit it after the water box it would die on me then rough idle. Wheatley sent me a newer 0411 pcm to correct the efans from grounding pin 42 while the truck is running, corrected that now its dying out on me when I get off the gas after a quick punch, Idk...
Old 06-26-2010, 11:10 PM
sureshot's Avatar
If you're running a mail-order tune with FI, you need to ditch it! You need and in-person tune or a dyno tune.
Quick Reply: Procharged times....
