TIME SLIP DATABASE
Ran My truck in the 1/8 Tonight
Old 09-27-2008, 09:10 AM
RandomHero's Avatar
Originally Posted by sickREDsierra
i pulled the same 60's with my old 4.8, 3K stall, and 3.23 open diff.
only difference was it didnt have enough power to spin
seriously though, with some DOT's and the locker/4.11 setup, 8's shouldnt be a problem for you at all... maybe 8.70's or so with stickys and a good TC flash off the line.
I feel pretty confident you're right. I'm not even flashing the converter off the line otherwise I pull 2.6+ 60' times.
Old 09-27-2008, 09:46 AM
TXsilverado's Avatar
theres alot left in the truck with the 4.10's tru-trac and sticky tires. your converter is only as good as your tires.
Old 09-27-2008, 09:56 AM
ZO6Ted's Avatar
I once did a gear change on a 77 Camaro from 2.73 to 3.73 and gained an ENTIRE SECOND in the 1/8 but I had traction.
Old 09-28-2008, 12:02 PM
94f150's Avatar
My RCSB v6 silverado ran 10.5 in the 1/8th with a K&N filter, and exhaust cutout. 60 foot was a 2.3 do to spinning.
Is that good for a v6?
I would like to see what I can get now. WIth all the stuff I put in it since then, I hope to get in the 9's. (1/8th)
Old 09-28-2008, 12:24 PM
Resident Retard
BlackGMC's Avatar
Congrats on making it to the track! Did you take any logs of your run?
Old 09-28-2008, 08:16 PM
RandomHero's Avatar
I wish I could have. The track is only 10 minutes away though so I'll be going back once I get my wideband installed and do some real tuning/logging.
Old 09-28-2008, 08:36 PM
TouchOfEvil04's Avatar
At least you know a base to judge your gains now.
My worst 60ft ever was a 3.4 lol. This was also a peg leg.
Old 09-29-2008, 09:47 AM
TOTM: January 2007
Last Call's Avatar
Sticky tires, 4.10's, and an lsd will shave .5-.7 off your time depending how you 60'.
Old 09-29-2008, 04:22 PM
sickREDsierra's Avatar
i think the general rule of thumb is whatever you save on the 60' should more than double on the big end, in the 1/4 mile.
i am not sure how much the ratio would be in the 1/8th.. i will figure it out soon though!
Old 09-29-2008, 05:42 PM
RandomHero's Avatar
I hope you guys are right. My truetrac came in today so now I just need to find a good price on some 4.10s and find someone up here who can install it all since I don't feel like spending the money on tools I'll use 1 time.
wrb002
08-31-2015 12:00 PM
Mossyoakglock
07-17-2015 08:30 AM
black6spdz
07-16-2015 01:32 AM
fcompean
07-15-2015 09:55 PM
4B11T
07-13-2015 03:48 PM
Quick Reply: Ran My truck in the 1/8 Tonight
