Ran my truck finally (Trick Turbo)
definately work on your 60', that is a nice mph, i trapped 99mph when I ran a 13.2 in my 5.3, by the way were in pearland are you? i live right off of blackhawk, I would like to check out how a turbo looks like...
Truck Sponsor
Well went out to hrp finally ran my truck withTurbo and street tune (Wheatley is a great tuner to deal with by the way).
Before turbo:
60' 2.509
330 6.883
1/8 10.374
MPH 70.21
1000 13.398
1/4 15.923
MPH 89.59
After turbo @6psi:
60' 2.429
330 6.379
1/8 9.559
MPH 78.21
1/4 14.515
99.68
The truck pulls really strong but 1/4 time is slower then i expected. Im thinking the 20's and 3.23 are really killing me off the line.
Before turbo:
60' 2.509
330 6.883
1/8 10.374
MPH 70.21
1000 13.398
1/4 15.923
MPH 89.59
After turbo @6psi:
60' 2.429
330 6.379
1/8 9.559
MPH 78.21
1/4 14.515
99.68
8mph by the 1/8 is not bad,
and 10mph by the 1/4 is showing the truck can run much quicker just get the 60 down.
BTW how much boost did you launch with?
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
![Stupid](https://www.performancetrucks.net/forums/images/smilies2/stupid.gif)
What stalls are yall running with a turbo? Believe me i cant wait to bump it up to 10 psi, but thats gonna have to wait till around xmas time next year when i can get a better trans. Also i dont know how accurate it is but the instant mpg in the truck is telling me im getting around 22-23 mpg on the highway, i didnt get a turbo for mpg but its still nice to know...
Truck Sponsor
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
MOOBIES Moderator
I've always heard that turbos like load, so staying with the lower (numerically) gear might actually be better. I'm sure there's a point at which you could have too low of a gear in it, but I don't think the 3.23's are hurting you as much as the converter and rim/tire setup.
Before turbo:
60' 2.509
330 6.883
1/8 10.374
MPH 70.21
1000 13.398
1/4 15.923
MPH 89.59
After turbo @6psi:
60' 2.429
330 6.379
1/8 9.559
MPH 78.21
1/4 14.515
99.68
Before turbo:
60' 2.509
330 6.883
1/8 10.374
MPH 70.21
1000 13.398
1/4 15.923
MPH 89.59
After turbo @6psi:
60' 2.429
330 6.379
1/8 9.559
MPH 78.21
1/4 14.515
99.68
ALL runs in 4hi
5200 lbs race weight, 3.42's, 20's, 2000 stock stall (4wd)
Before turbo:
60' 2.445
330 6.820
1/8 10.401
mph 67.82 63 deg. temp
After Turbo 5lbs, fmic, zo6 cam
5300 lbs race weight, same as above
60' 2.375
330 6.355
1/8 9.54 82 deg. temp
mph 76.12 I remember thinking, what a pos.
Changed gears to 4.10's, much better
same as above
60' 2.093
330 5.848
1/8 8.902
mph 79.95 89 deg. temp
Increase boost to 9lbs. vig 3000, sweet!
same as above
60' 1.768
330 5.211
1/8 8.116
mph 83.58 88 deg. temp
More tuning, 44 deg. temp, oops what a bummer.
same as above
60' 1.698
330 4.916
1/8 7.641
mph 88.38
Note: do not get too agressive on the tune! several pistons didn't make it.
Should have had meth.
