Ran the truck yesterday
New PB with the 80e. Still confident it has more in it. Track was crowded and I have a weak battery. Had to leave the truck running in the staging lanes so I could power the bottle heater. The engine never got cooled down to the point that I make my better runs. IAT's were sky high all day.
First pass of the day. Soon as I arrived and go unloaded. I was able to basically drive right up to the line and go after I go unloaded.
60' 1.68
1/8 7.41 @ 92.0
1/4 11.68 @ 114.3
A whopping .03 better than previous best but I'll take it considering this is with the 80e. The trans performed perfectly all day.
60' 1.68
1/8 7.41 @ 92.0
1/4 11.68 @ 114.3
Yep I'd read that the weight difference between the two was right at 22 lbs.
Going through the logs. Due to the IAT's and my conservative timing setups with nitrous I'm pulling a butt load of timing. The 11.68 run started at 17 and down to 12 total timing through the traps. Clean and no knock. Helps explain why I didn't see the mph I expected. I'm back to the track in a couple weeks. Going to make up 3 or 4 tunes with different timing profiles to try.
Great times!
