TIME SLIP DATABASE
Regular cab drag setup questions
Old 02-12-2012, 06:44 PM
  #51
1989k1500's Avatar
One guy on here went 1.4X 60' with a 2/4 and cal tracs with drag shocks.
Old 02-12-2012, 08:11 PM
  #52
blue0453's Avatar
Originally Posted by Blown06
Regular cab short bed suspension formula for 1.5 60's on a 4/6 drop:
Front:
2" drop spindles
2" drop springs
QA1 12 way adjustables (will take very little modification to fit properly)
Remove front sway bar (you won't even notice it gone when shocks are set for street driving)
Correct alignment
Rear:
6" flip kit
C-notch
Clamp overload leaf in front only
QA1 12 way adjustables (both mounted straight up and down on back of rearend)
4* axle shims to reset driveshaft angle
Slicks
It took me 3 trips to the track to get the shocks dialed in where I thought they where perfect. If I remeber right, for me it was 5 clicks in the front and 4 clicks in the back.
With good power and correct converter/gear this setup is easy and deadly. No need for traction bars, aftermarket leafsprings, leafspring disassembly, aftermarket sway bars, shitty springs or shocks.
good info right there...
gnasty1521
35
11-19-2015 11:42 PM
Shtbox
08-02-2015 10:52 PM
USMCvet0311
08-01-2015 07:45 AM
Jake75
07-22-2015 09:20 PM
Quick Reply: Regular cab drag setup questions
