TIME SLIP DATABASE
so close to 7s
Old 06-03-2011, 12:09 PM
slowec's Avatar
Lower those tires to 13 psi. manually shift 1st to second blip the N20 in second and let the burnout pull you forward onto some cleaner surface. try leaving off idle too. There is plenty of improvement room in technique I believe. I am assuming you are spinning when you leave right?
Old 06-03-2011, 12:44 PM
Black'Rado's Avatar
yea it spins pretty bad on launch, i sold my radials so im stepping up to a slick soon
Old 06-03-2011, 03:18 PM
iamkeniff's Avatar
do you drive through the water box or back into it? i never had a problem with traction in my truck with a 3600 converter.
i back into the water box, spin it over a little, come out and burn it a couple seconds and then line it up. on a stock converter you shouldnt have any traction problems what so ever
Old 06-03-2011, 03:49 PM
SLOXCAB's Avatar
Must not be doing good enough burnouts cause I dont spin at all even when I had no caltracs and im n/a
Vortec350ss
01-12-2016 10:36 PM
00loudchevy
12-03-2015 05:54 PM
Avalanche2002
11-30-2015 07:31 AM
94f150
09-28-2015 05:28 PM
Quick Reply: so close to 7s
