so close to 7s
Lower those tires to 13 psi. manually shift 1st to second blip the N20 in second and let the burnout pull you forward onto some cleaner surface. try leaving off idle too. There is plenty of improvement room in technique I believe. I am assuming you are spinning when you leave right?
do you drive through the water box or back into it? i never had a problem with traction in my truck with a 3600 converter.
i back into the water box, spin it over a little, come out and burn it a couple seconds and then line it up. on a stock converter you shouldnt have any traction problems what so ever
Vortec350ss
01-12-2016 10:36 PM
