So close i can taste it!!!
I would look into how far past redline you can take your motor. I mean 75-100' aint squat and I bet you easily pop a 13 if you can extent 3rd gear a bit.
Originally Posted by Linda
The worst that can happen is i blow it up... .
Doubtful. Most engines can run short blips well past "redline" but I dont know enough about the 8.1Ls to know what their springs and such can handle. I mean redline is like 6k on the 5.3L trucks but I used to run mine to 6200 all the time on stock internals
Originally Posted by Norm02
Not trying to hijack the thread, but why did you get rid of the turbo and go to a radix??
I was gonna build a RCSB race truck and put the turbo on it and make the Z71 N/A. Ran across a great deal on the blower so stuck it on the Z71. That's pretty much it. It wasnt a real STS vs Radix choise. Just weird circumstances. Both are great setups and right now I would be hard pressed to choose one over the other.
Originally Posted by DanaliHD
crank up the boost. 5lbs is a joke. very impressive time for such low boost. I say go to at least 8lbs. I ran basically the same times on 15lbs that I did on 12 because of belt slippage.
