Stall 3600-4000
Stall 3600-4000
I just got my torque converter restalled from 3600-4000. How much of a differance do u think this will make?
Where's the Beef?
Nevermind. I see you did ask.
https://www.performancetrucks.net/fo...d.php?t=451400
https://www.performancetrucks.net/fo...d.php?t=452131
So you got your answer multiple times and now that you've loosened it your STILL asking?
if you use it as an everyday driver i honestly think it will be to big idk the trans probly could handle it but i wouldnt have that big of a stall unless im trying to pull the tires off the ground
Where's the Beef?
Add a cooler to keep heat down and drive like normal. Once it's locked it'll be at the proper cruising RPM
