STS getting closer to 10.s
#32
How do I change this text
Yep the Z was LS1 powered, and bad ***. It was the best race for me that day. Every gear change I'd gain alittle ground, then loose it to his better power weight ratio....
Have you talked to him about that day? Does he normally run 10.xxs?
#33
Restricted User
that z has a stock rear end still. he got into the 10.90s at i think 124 when i saw him at sears point. the motor is a stock ls1 with a little cam and afr heads and thats it. oh yah t56 6 speed. he said he was going to go into the high 4s like 4.80s for rear end gears so will be better. also a nx 150 shot. that car moves for what it is. still running a single 3 inch exhaust also.
#34
How much does it wiegh?
#36
Did you turn the front t-bars down some? That may help with traction. Maybe some cal-tracs. What about just running in 2wd with some slicks Im sure someone around there has a set you oculd borrow. Sure would be sweet to see you hit 10s on a sotck 6L and 67.
I wonder how it would act if I found some slicks that are the same sizes as the street tires, and still used 4wd but with slicks in the rear only?
#38
2nd fastest 5.3 ECSB
Originally Posted by silverbrick
i dont know if this has already been covered, but what's keeping you from putting slicks on all 4? turning issues?
I dont know about WidleRacing but I can't get all 4 to spin at will so it would be a waste of $$
BUT
You could run slicks and skinnys and still get a good 4wd launch.
#39
BUT
BUT
