well the shorter tire will force you into shifting earlier and lugg across the 1/8th if that is your venue. A taller tire might help if you are really winding it up like that
Ya that is why i am asking, i am at that threshold where if went shorter it could actually make me slower...
I wouldn't do it. When I ran those 26" drag radials (used and bald but got for cheap) I had some problems with traction and it made the rear want to hop a little. I think you should keep the 28"s
Well i rarely get to go to the 1/4 mile track so i am not sure on the rpm... I normally go to the 1/8th and i usually shift a little bit before the traps... So usually i just keep it in 2nd rev up to 7000-7100ish rather than shifting into 3rd...
if that's the case your better off with the tire diameter you have now, maybe even taller will help.
