TIME SLIP DATABASE
tonight at PRP new bests
Old 09-01-2006, 05:54 PM
FormerVendor
Ross @ EDO's Avatar
I would have honestly expected more out of it, with 5.3s with truck intakes less cubes, smaller stalls and less CR running faster times granted it wasnt in this heat but V8 ran 12.8-12.9 in the heat a couple of months back down here in TX.
Ive ran pretty much the same time in the HEAT in full street trim, and im only running a Comp 224, TCI3000, 3.42 gears, STOCK heads, Stock truck intake, and the usual bolt-ons.
Old 09-01-2006, 06:30 PM
5 year bitches!
Quik's Avatar
yea im still expecting more out of this. im still blowing black smoke but my A/F is around 13.0. right now im toying with gearing. im low in the rpms with the 28s and 410s with 410s and 26s im 6100 still not where i need to be. also different tracks different times. its not at its full potential yet thats for sure. i might start to play with the tune some more when i get the new gearing
but im also full street weight no weight difference from track to street
also V8 and bluecajun are lighter trucks they weigh in about 500lbs or so less then I am and 2/10s faster
Old 09-01-2006, 08:22 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
They weigh in at about 4600-4800 not that big a difference. Not ******* your setup at all just trying to figure out why you arent where you "should" be. I would think you should be atleast a half second faster. Good luck getting your bugs worked out. The black smoke thing is a bit puzzling.
Old 09-01-2006, 08:35 PM
v8
17,16,15,14,13,12,11 Drvr
he is running about 2-3/10's faster then i'am right now, since the last time I checked at the track the truck weighed in at 4320 and went 12.80 at 104.9? it was also 88* outside too, since then I haven't had any tires to get times with, that will change on the 7th of sept. though hahaha.
Quik, you will be low 12's high 11's in cold weather and take the weight off, like I said before you know what it does on the street, now its time to get your fastest times in race form. good luck.
Old 09-01-2006, 08:40 PM
5 year bitches!
Quik's Avatar
they said they were around 4100 race weight so just going off what they said and yes trust me i should be about a half second faster. i might even be a few more lbs on top of what i think im at. i havent weight the truck in years and when i did i was 4500 and that was before the leather, wheels, skirts, system. i know the gearing is hurting some right now which will be taken care of soon. could also be im running mac midlenghts and not full headers dunno, maybe my exhaust is restricting me some. the headers are 1 3/4 but on the inside they are only 1 5/8s since there is alot of weld along the flange. i didnt know that before iput them on and since then learned that most ppl port them to help with flow
as for the black smoke its really ******* pissing me off. ive tried different tunes and all the same results. black smoke
Old 09-01-2006, 08:45 PM
5 year bitches!
Quik's Avatar
thanks and yea im going on a diet for next week, just pisses me off some cause of some smoking issues im having and still testing out different results for the 60's.
as for race trim what are you and blue doing for reduction? i know my leather isnt as light as my stock seats and no where near the weight of a base interior seats
Old 09-02-2006, 12:51 AM
FormerVendor
Ross @ EDO's Avatar
This is one of those situations where I am going to say bigger is not always better. This is just IMO. This setup in a car would be perfect, but in a heavy truck its just too much, like i said its just IMO.
Old 09-02-2006, 10:13 AM
5 year bitches!
Quik's Avatar
se you could be wrong on your opinion also. look at the elevations im racing at compared to some of you. that will play a huge rule in differences between ppl's times. i know if i go to ATCO its about 3/10s faster then the track im at now or if i go to QCR its about 2/10s slower then PRP this is why some ppl calculate their times. if i did that my times would be about 12.4 full weight but i go by what slips i get and no a correction figure.
and im still working out bugs as in what gears i need. in a roll i do pretty well. ran a C6 on way back from the track 3 times and each time i would put lenghts on him. ran a buddy's SSS that runs 12.6 consistant and i put lenghts on him again
just figuring out i need gearing might solve some of my issues, so only time will tell what is going on
Old 09-02-2006, 02:18 PM
11 Second Truck Club
bluecajun5.3's Avatar
good luck with the set up
you'll get there, it just takes some time and learning different combo's that work
Old 09-02-2006, 03:06 PM
Sport Side's Avatar
We walked my buddies H/C/I modded F-body from mid 12s to an 11.9 in one night of true testing and tuning... Mainly messing with shift points and A/F and timing out of the hole. So yea, keep playing around with the tune and tweaking this or that and you'll be where you want.
thompson
12-27-2017 06:48 AM
bearden86
26
11-15-2015 03:58 PM
shootermwc
10-08-2015 01:45 PM
blackedoutchevy22
10-01-2015 08:07 PM
Rockrz
09-29-2015 09:07 AM
Quick Reply: tonight at PRP new bests
