TIME SLIP DATABASE
track problems
Old 11-19-2009, 12:46 AM
SincalT/A's Avatar
Did you pin your crank?
Old 11-19-2009, 12:55 AM
Most Hated's Avatar
yes i pinned my crank , my belt was slipping at first but i added vht and it helpt out alot , i think ima send my pi to be restslled into a 4k or 4400
Old 11-19-2009, 12:56 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Did you spay on the 12.56 run?
Old 11-19-2009, 01:06 AM
Most Hated's Avatar
nope no spray
Old 11-19-2009, 01:15 AM
I say get the converter better matched to that cam, or consider a different cam altogether(with the matching converter).
Old 11-19-2009, 01:31 AM
Most Hated's Avatar
that cam works bad *** on the street its fawkin fast
Old 11-19-2009, 01:35 AM
Most Hated's Avatar
so i guess ill get a bigger verter
Old 11-19-2009, 09:52 AM
1dirtybird's Avatar
Originally Posted by Most Hated
yea a friend of mine tuned it but the af is good wen we tuned it on the street but on the street it would lose 2 lbs at shift 2-3 with 25" tall tires at the track i use 28" slicks
There is an issue right there! You added 3 inches of tire to your ride. You probably get a hard spin on the shift, which holds boost on the street. Also the taller tire adds mass and takes away gear. You need a trans tune for the taller tire too. Try a 26X10X16 tire and you may be much happier.
Old 11-19-2009, 09:57 AM
1dirtybird's Avatar
Ohh and nice times btw! Looks like 11's in your near future!
Old 11-19-2009, 03:02 PM
Most Hated's Avatar
a friend of mine had the same setup , same stall and would pick up 10lbs right from the start, so theirs defendantly some thing wrong
Quick Reply: track problems
