traction tonight?
traction tonight?
so tonight im headed to the strip.....trying to decide if i should launch in 4hi or 2wd......on the street if i launch in 2wd i spin for about 60-80 ft.....when i launch in 4hi i usually put into 2wd at the end of 1st and then it lets loose and i go squirrley....i loose tons of power if i run 4hi the whole way though.....any ideas? i'm running 275/65/18 bfg rugged trails....its in between an all terrain and radial.
most definately......im hoping ill just hook considering all the ruber on the track.....i havent ran the truck in about a yr and im running with a few more ponies than last time....ill just have to test and tune with traction tonight
I run mine in 4hi through the 1/4. Manual transfercase. I have dr's on all four corners. I do a 2wd burnout, then stick it in 4hi for the pass. I check my tire rollout after every track day and rotate them acordingly to keep the rollout to within an 1/8".
Vortec350ss
01-12-2016 10:36 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
TAPyvehc93
09-14-2015 01:22 PM
