TIME SLIP DATABASE
trying to get a 10sec pass 4.8l turbo boost only
Old 09-29-2011, 01:40 AM
9 Second Truck Club
stock48's Avatar
Put some timing to it during spool and launch
Old 09-29-2011, 06:33 AM
Lil brother PI's Avatar
runig strong very nice
Old 09-29-2011, 07:45 AM
sprayedenali's Avatar
Sy/Ty shuffle! It'll build some boost......
Old 09-30-2011, 12:50 AM
Most Hated's Avatar
??????????????? wats that
Old 09-30-2011, 08:35 AM
slowec's Avatar
1) When you're ready to go/are staged. put the truck in NEUTRAL.
2) Put your foot on the brake, and push it down VERY HARD
3) While holding down the brake, rev on the gas pedal to around 3500-4000rpm a couple times. This will create vacuum pressure, and will allow the brake pedal to sink a few inches further (usually to the floor) for a better hold.
4) While holding, slowly get on the gas to build boost pressure
5) Watch your boost gauge (your aftermarket one is better if you have one) When it gets to around 5PSI or a bit over (don't go too high or you will break your propshaft) Let off the brake while simultaneously flooring the gas.
( ripped off from the sy ty forums)
STOCK48, Post a screen shot of what kind of timing you are suggesting ...
hell, it don't hurt to ask.
Old 09-30-2011, 09:32 AM
I'll post a video of me at the track in a little bit so you can see my process
Old 09-30-2011, 09:43 AM
slowlsx's Avatar
The shuffle does work!!! I can't build any boost but when I shuffle I can build 5-7 lbs easy
Old 09-30-2011, 10:52 AM
Most Hated's Avatar
u learn something new every day thanx bro
kool post it here
dammm i need that bad cuz im taking of at 0vac lol
Old 09-30-2011, 12:20 PM
9 Second Truck Club
tarinitup's Avatar
Syty with two step is what you need. The two step cuts your power in half and let's you build more boost until you let off the brake. I have made as much as 9 psi at 3600 rpm like this.
Old 09-30-2011, 07:20 PM
Most Hated's Avatar
we have a 2 step at the shop ill try it out to see if i can dip into the 10s
OHsixLS3
12-27-2016 09:30 AM
lxcoupe
07-27-2015 08:19 PM
Choda
07-21-2015 03:47 PM
black6spdz
07-16-2015 01:32 AM
Quick Reply: trying to get a 10sec pass 4.8l turbo boost only
