Unusually slow?
The filter was dirty.. I'm actually cleaning it now. Weather was about as good as it gets down here.. clear skies, pretty dry, ~mid 70s?.... Shifting around 57-5800. Tune is updated, except theres still a problem with the new gears and tires. Throwing an ABS light still, but retune is on its way. Still a 99 PCM... Do you think that could be an issue? I'm using my 99 fuel rail w/ 05 injectors and 99 throttle cable. I went through the traps around 3700-4000 in 3rd.
10 Second Club
yeah starts pretty easy. Once in a blue moon it will kinda sputter when starting.. but idles fine and no other issues. So you think I should request a newer PCM from Nelson on my retune?
Whenever you get a chance, post all the #'s on the slip it will help determine where something is going on. I'm sure trever1t or somebody with a similar weighted truck on the fastest truck list has a old timeslip you can compare mods/times.
Definitely not right. I've never weighed mine. I race with the tonneau cover on. All I do is yank the spare tire so I can mark my parking space. My best run to date (1/8 mile):
60 - 2.294
330 - 6.507
1/8 - 10.008
@ 70.77
A week later I went to a different track for my only 1/4 times to date. I can't find the slip right now, but I was disappointed with a 15.7. Not sure what was up as my 60s were a full tenth slower than at the 1/8 track.
Mods are below (minus the catback), stock 3.73 gears, 30" tires. I take off in 4wd so I don't have to scrub the tires (not that it's much of a problem anyway). The tune is by me and at this stage is mostly just fixing the factory fueling - I intend to start turning the wick up more this season.
60 - 2.294
330 - 6.507
1/8 - 10.008
@ 70.77
11 Second Club
here my slip when i had just pacesetter longtubes,corsa catback, intake, vette servo, 3.42 gears, and wheatly mail order tune
60' 2.369
1/8 10.025 at im going to guess 72 because this slip doesnt have mph but my others were 71.80 and this was my fastest time that night
1/4 15.413 at 90.20
it was about 85 degrees and there was alot of humidity.
60' 2.369
1/4 15.413 at 90.20
10 Second Club
ok I've got two timeslips... gain of stock vs. 35s was a little more than i originally thought, but still slow.
35s -
60' - 2.428
330' - 6.811
1/8 - 10.442 @ 68.0 MPH
1000 - 13.583
1/4 - 16.263 @ 83.60
stockers -
60' - 2.341
330' - 6.646
1/8 - 10.272 @ 67.55 mph
1000 - 13.466
1/4 - 16.186 @ 82.74 mph
35s -
60' - 2.428
330' - 6.811
1000 - 13.583
stockers -
60' - 2.341
330' - 6.646
1000 - 13.466
Larger tire usually results in higher trap speeds, especially when he's cutting better 60ft times with the stockers. He's getting to the end quicker with the stockers not faster.
