wanting to get in the low 14 high 13 seconds
I have a 97 Chevy silverado extended cab two wheel drive. It has a 350 5.7L with the vortec heads. I have longtube headers with straight pipe with a x pipe and turn downs. K and n cold air intake, e- fans, underdrive pulley on the crank, 373 gears with posi traction, 8mm Taylor wires, msd coil, ac delco cap and rotor, upgraded spider system, ngk plugs, and 100 shot wet kit from nos. Any ideas on what times I would run now and any help on me getting into the high 13 to low 14 seconds. Thanx in advance.
Banned
1 Post
a friend of mind had this same truck with out the 100 shot and with a hand held tuner ran 14.3's.
i also know someone that put the carb. intake on his with the edlebrock 6something throttle body n a reg cab and ran 13.7's all motor he did have a cam tho.
you should get low 14's no problem, i had an 96 chevy scsb with a vortec 350 and all that was done to it was knn cold air and a hyperjunk programmer and it ran a 15.2 with street tires. but it was kinda of a factory freak compared to others around, but i still think you should get anywhere from a 13.8-14.2 with you set up.
