Well I finally have some money to spend on the truck.
I have already bought tail light covers, headlight covers and a new grille. I'm getting the windows tinted next week and have ordered a superchip, K&N cold air intake and have gotten a Throttle body spacer on the way. What times (1/8 and 1/4) should I expect with just those two mods. I'm hoping .5 in the 1/4 and .25 in the 1/8. Also I'm looking to buy a cam and some heads and was wondering what I need and where to get them. After I do all of this I will then purchase my STS turbo. Thanks in advance for the info.
For those that don't know my truck is a 2001 single cab 5.3 RWD.
get you a tune instead of the handheld tuner and some ET Heads and a custom grind cam from CompCams and if you are into racing do a full bolt-on on the engine if you have the cash!!!!!!!!
i dont think youll see a half a second with the intake and tb spacer. the intake may at most give you .2 and the tb spacer will give you pretty much nothing . i think they have been proven to be pretty worthless but to each his own. they will make some noist though. im with the other guys on this one a tune would help a good amount.
Ah...well then poo..lol...I know a cam and heads would help alot. I only have about 1000dollars to spend. and I already bought the cold air and Chip(Damnit) so I'm left with 500...I found a Z06 cam on ebay and was wondering how long it would take someone to install it professionally?
2nd fastest 5.3 ECSB
First of all this thread does not belong in the Drag racing section
I think you should slow down a bit and do some reading. When it comes to cams, or other large engine mods like heads and FI, a bit of careful thought is required
Not trying to be an *** but you might save some big $$ if you do it right by learning from others. Then again, I guess it's part of the learning process
Corvette454l88
09-01-2016 01:24 AM
JFortner5
08-20-2015 06:13 PM
hirdlej
08-10-2015 10:51 PM
