went to the track, disappointed, help me out
ok, i thought for sure i would have been in the 14s, but i was in for a surpraise. i went yesterday and was some what heart broken
if yall dont know my setup, its a 97 ECSB 4x4, 355, zz4 cam, 9.7-1 CR, p&p 906 heads, full long tube headers and 2.5 inch exhuast and a CAI
1st problems i noticed, she wouldnt shift from 2nd-3rd right away, it would peg the rev limiter 2 or 3 times than shift, and my SES would start flashing towards the end of the track, but it didnt feel any different, till i left, but thats another story.
anyways, heres my times
4HI launch
60 ' = 2.391
330 = 6.600
1/8 = 10.132
mph = 69.88
1000 = 13.151
1/4 = 15.738
mph = 86.66
2HI launch
60' = 2.363
330 = 6.514
1/8 = 9.969
mph = 71.60
1000 = 12.915
1/4 = 15.452
mph = 88.44
now, when i left the track, i got on it through 2nd, and around 4500 RPM, it start spittin and sputterin, and missing (popping out the exhuast) and wouldnt pull any more. havent had time to check it out but it wont do it in 1st.
so, all advice welcome/needed
thanks yall
4HI launch
60 ' = 2.391
330 = 6.600
1/8 = 10.132
mph = 69.88
1000 = 13.151
1/4 = 15.738
mph = 86.66
2HI launch
60' = 2.363
330 = 6.514
1/8 = 9.969
mph = 71.60
1000 = 12.915
1/4 = 15.452
mph = 88.44
thanks yall
pull your plugs out and give em a look. A bliking light shows a misfire and that would explain the sputtering, check for burnt plugwires and just the normal things. Good luck and hope ya get it worked out!
yea i knew flashing SES means a constent miss, i just havent had a chance to look. i know the plug wires arent the best, they have been burnt but i never had a problem with them.
1 Post
my dads 95 z would hit the limiter on the 2-3 shift some times....he had a header leak and after fixing that it was fine! i still dont know why or how that would affect it?
like they said check your plugs and wires
I had a 94 and it would start to spit and sputter around those rpms, Especially in first for some reason. checked the plugs, wires, messed with the timing. nothing helped. pulled the fuel filter and finally found the problem. I couldn't blow through that filter if my life depended on it it was so clogged. I would start there.
