TIME SLIP DATABASE
what 60ft's with stock stall do you guys run?
Old 09-17-2010, 04:22 PM
JeRM82's Avatar
Question what 60ft's with stock stall do you guys run?
I'm going out to fontana sat/sun to see what kind of 60ft times I can get out of my truck with the cal trac bars off and JUST the RS9000 to see what th truck can do on the stock stall....
What kind of 60ft times do you guys pull on drag radials with the stock stall and decent shocks? I'd lik to get 2.0's out of it....not sure if getting anything more out of if is possible with the stock stall....what do you guys think?
Old 09-17-2010, 05:30 PM
13 Second Truck Club
grey matter 04's Avatar
the best mine did was a 2.4 on stock stall with 3.42 gear
no spin dead hooked,just was lazy as hell out the hole
Old 09-17-2010, 05:35 PM
iamkeniff's Avatar
2.4ish but im a CC and was on street tires, dead hook also. 3:42s and 31.5" tires
2.0 with a 3200 converter only
1.82 with 6.2, cam, 4:10s on DRs
Old 09-17-2010, 05:52 PM
KDavis04ss's Avatar
2.1 60ft stock
1.8 with circle D 3200
Old 09-17-2010, 06:39 PM
OUT2WIN's Avatar
2.01 on 26x11.50.16 et streets
1.86 on same tires with nitrous
Old 09-17-2010, 07:39 PM
mhotrodscooter's Avatar
2.178 on street tires with 25 psi! Hooked good but lugged the motor!
Old 09-17-2010, 08:07 PM
Hunt&Fisherator
silver-mod-o's Avatar
I pulled several low 1.9s with a stock 60E converter, 4.10s, and a small cam in a 5.3 with a 150 shot spinning in an ext cab.
Old 09-18-2010, 03:16 AM
LS1TRUCKGUY's Avatar
consistent 2.1's with bolt-ons/4:10's on street tires with stock verter
i pulled a 2.009 once upon a time
Old 09-18-2010, 08:39 AM
SCOTT_A's Avatar
1.9s with stock stall in an 80E. 3.70 Gears and Nitto Drag radials
Old 09-18-2010, 11:23 AM
Nevada79's Avatar
Consistant 2.0's with stock lq9 with volant intake, stainless works headers and exhaust, stock converter in front of a mildly rebuilt 4L65E with shift kit, AWD and 4.11 gears.
Quick Reply: what 60ft's with stock stall do you guys run?
