TIME SLIP DATABASE
What kind of times to expect with 450rwhp
Old 07-23-2012 | 12:31 AM
ltr450ryder's Avatar
Pitman I think it was ran low 11s with his 402 and it made like 445rwhp but I don't know his hole set either. Hopefully he will pop in.
Old 07-23-2012 | 12:39 AM
oakley6575's Avatar
Wow that truck must be light as ****. I need to get my truck weighed. I have a lot of extras on my truck that could be taken off. Bed liner, snug top, subs/amps, ect.
Old 07-23-2012 | 12:51 AM
oakley6575's Avatar
Fossil said this back in 2010:
450rwhp/440rwtq with 232/238 .600/.600 lift 113 lsa. CR a very low 10.8
Best 1/4 mile pass Oct 09 11.78
I will check out pitmans threads.
Old 07-23-2012 | 01:50 AM
62nalide's Avatar
im sure 11s could be possible in a rcsb, my nnbs ccsb with 422rwhp hit 12.97
Old 07-23-2012 | 01:56 AM
oakley6575's Avatar
I would really be happy with anything in the 12's. Just need to get some dr's the the funds are available
Old 07-23-2012 | 01:59 AM
oakley6575's Avatar
I wish las vegas motor speedway would have more track dates available. They only have one time a month where the public can go out to race. And slicks are not allowed, only DOT radials.
Old 07-23-2012 | 07:11 AM
pittman's Avatar
My truck is 4140lbs on street tires with me in it. It is probably 4025 lb with my drag setup. Here is my last dyno and time slips. I didn't get a very good sixty foot or I could have been a little better.
It will all depend on your setup and weight, if you will hit 11's.
Old 07-23-2012 | 07:20 AM
pittman's Avatar
Trying to find some 450rwhp trucks on the site with track times but I'm having a hard time. What kind of times would you expect from a full weight rcsb with 28" tall drag radials?
Looks like you have a nice street setup for sure. To hit 11's you will probably need a little more Stall, and at least a 410-456 gear. Did you get a dyno sheet ? You will need a good torque curve to get that beast rolling. Maybe not a high torque number, but good power under the curve.
Post up some pics too !!
Just noticed you have an iron block..so you have a few more lbs on the nose (70 lb ?). Maybe get a fiberglass bumper and one of those real small race batteries to make up some of the difference. Drain your windshield washer too..water is about 7lb per gallon.
Old 07-23-2012 | 11:39 PM
oakley6575's Avatar
Don't even get me started about the dyno sheet... haha the "tuner" I went to basically only changed the spark tables, and some idle tables from a stock 6.0L tune. He didn't make any changes to VE, MAF, injector data, ect for a motor with 40 more cubic inches, better flowing heads, and a decent size cam. It ran like complete **** when I got it off the dyno and for the next month or so until I figured out HP Tuners. When I got a wideband on the truck, the afr was mid 14's under WOT.. It made 435hp and 400ftlbs with his tune on it. I haven't been able to get it back on the dyno since. Sorry for the RANT but I will post that bullshit graph up.
All of those are great suggestions Pittman! I currently have 3.42's so those won't help much. I will start shedding weight everywhere I can think of before August 18th. I really hope I can get some dr's before then.
Old 07-24-2012 | 12:28 AM
oakley6575's Avatar
