What should i run?
What should i run?
I have an 02 rcsb 4x4 5.3 and i plan on running long tubes, efans, 2600 stall, 4:10's, 210/218 .531/.531 114 cam, shift kit, cai, 150 shot and a good tune what do you thinf it will run in the 1/4
i have shortys, 2600 stall and a 100 shot and i ran high 14's. i am want to run high 12's do you think that will get me there?..if not what else do i need?
I went to the track again this weekend. with 2600 stall shortys and 150 wet shot i ran a 14.5...i was lunching in 4 high. does anyone think it would be quicker to lunch in 2wd with some good drag radials?
Where do you run your truck at? I usually run at Bunker Hill or Muncie. I do not see why you wont meet your goal of high 12's with all the mods you have done. What 60' times are you getting in 4wd? I would think that launching in 2wd w/ Drag Radials would be a better way to launch in my opinion. The best 60' I got was a 1.77 at Bunker Hill w/o track prep. Let me know. BTW, Its nice to see someone else from Indiana.
I'm reading your post again and you only have 2600 stall, 150 Shot & Shorty Headers and you ran a 14.5? If that is the case I would say that is not bad pending your 60' time. You need to get the CAI, Cam, Catback Exhaust, Pacesetter LT's w/ Y-pipe, 3.73 Gears w/Posi, E-fans, M&H Drag Radials, Tune and you will be in the 12's no problem. The reason I suggested 3.73 gears is because I wish I had done the 3.73's instead of the 4.10's, I am not really sure why?
Yea with those 60' times I would see no problem getting into the 12's if you did all the mods mentioned above. We should meet at Bunker Hill 1/8 mile track sometime, I could let you try the slicks out to see if you like them or not. Bunker Hill is only 60 miles from North Judson and is about the same for myself. Is US 41 a 1/8 mile or 1/4 mile track? Later.
us41 is 1/4. i just bought some et streets im going to try and get to the track this weekend and see if it helps. monday im ordering the the cam, 4:10,lt, cai, shiftkit and servos and as soon as there in im goin to go get it tuned. I really hope im in the 12 with the 150 shot. im not sure what cam to go with, im thinkin about the gm hot cam is there any one else runing this cam with nitrous?
