what should i run in the blackbeast??????
doesn't know what quit means
well i have an extended cab with a 6.2 with p&p heads and milled heads i have 1 7/8 headers a crank pulley and a intake with a custom grind cam speced by allen nelson i have 410s with trutrac and a 3800 stall from circle d what should i be hittin on this weather????? what about with a 125 shot of nitrous???????
Come on man should have gave out more details then that as in specific cam specs, made for nitrous or for motor. Or maybe previous mods before certaint mods you have done afterwards. Me knowing it ran low 13's before cam abd gears would have Ben pretty important. Nobody is replying to ur thread because you don't have enough information for peope to give a solid estimate. G/L
Unless it's another guy from the RGV I don't see you getting much realistic help.
It sounds like you have a strong setup, but ******* people's opinions when you don't give us enough information isn't going to get you any help on here.
You're going to have to list your trap speed, what the real specs of your cam are, and what kind of traction setup you have.
With all these variables, I don't see how you can expect us to make a realistic guess.
