TIME SLIP DATABASE
What times to expect
Old 03-15-2006, 02:50 PM
Norm02's Avatar
Originally Posted by F8L Z71
if you are having trouble with traction go for it. I never had problems with it and similar mods.
It didnt have the do the above method until I got the stall in But if ytou do spin then that is the way to do it.
I am not sure what it will be like on a track. On the street I spin off the line for a good 2-3 seconds. I figured that I could launch a lot harder out of the hole in 4wd also. Should I do it in auto 4wd or 4hi?
Old 03-15-2006, 02:55 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
I have to take off in 4hi also, anything less and i am spinning all the way down the track.
I accidently left 100' of tire the other day at a friend's house. I literally had no idea that both tires were spinning the whole time as i drove off .
Wish the F'N rain would stop already, seems like 3 months since i've seen the sun!
Whippled 496's Avatar
...4hi
Old 03-15-2006, 04:47 PM
F8L Z71's Avatar
Originally Posted by Linda
I was spinning through 3rd gear.... . Launching in 4hi made a huge difference.
You guys are not stock duh..... lol
His truck is basically stock and thus might not need to launch in 4wd unless track prep is crap or he does a burnout prior to staging (which a lot of new people do before they realize its not needed on street tires). Mine didnt most of the time.
To answer your question, yes use 4HI, then hit 2wd once you start moving and it should shift out just fine. Once you start making big HP that trick doesnt always work anymore though and you have to run 4Hi all the way through the 1/4
Old 03-16-2006, 12:24 AM
hog
hog's Avatar
Do not drag race in Auto 4wd, 4 hi only.
Its bad for some part as it all of a sudden engages, when it in 4wd from the tsrat there is less stress on parts.
peace
Hog
Old 03-16-2006, 07:50 AM
TurboGibbs's Avatar
peace
Hog
Exactly what he said, but to clarrify, auto 4wd only auto enguages 4wd when you have wheel spin. If it doesn't tear something up on the track surface it will slow your time down non the less.
Old 03-16-2006, 08:15 AM
Cuz I AM a BADMOFO
BADMOFO's Avatar
Mudz5.3 ran a 15.6 in his truck which was simillarly modded.
Old 03-16-2006, 01:58 PM
Norm02's Avatar
I am really wanting to hit low 15's high 14's. Is that just not possible with the mods that i have and removing my spare and the tail gate? I still have a factory waranty so I am kind of limited to the mods that I can do, not to mention that I am college student. I really thought that my tb spacer would cut at least .5 off my Ets.
Old 03-16-2006, 02:08 PM
I still have 6 months/16,000 miles left on my warranty...... Not to sure i could make use of it anymore though without going through a few removals.
Old 03-18-2006, 07:36 PM
Norm02's Avatar
What mod should i do next to ensure that I will hit 14's? Something that doesn't cost $4,000 and won't void my warranty.
Quick Reply: What times to expect
