What transmission?
What transmission?
Ok I have a 91' GMC ext cab 2wd sierra pickup. tubbed, caged, 5.14 gears with 31x18x15 street tire and 33x17x15 good year slicks with a blown injected ls1. On base tune 9lbs it made 843Hp 749tq. I will be cranking it u to 16-20lbs of boost. I haven't got the truck weighed but i'm guessing in the 3,300lb range. I have been thinking that a glide with brake isn't the ideal tranny for this application?? The holley dominator ecu will control all functions of the 4l80e transmission so that is a plus that route. I was thinking more in the lines of a built 4l80E or biting the bullet and putting in either a bruno lenco or the lenco st1200 clutch. The truck will be a street strip but mostly strip. let me know what you all think.
I think its all goin to come down to just how much you wanted to drive it on the street.
If it were me id put a built 80e in with a tbrake.
But if its more strip then a 400 or glide with a T brake.
With the 5.14 gears and tire size. What would my trap rpm be? That's why i'm worried about a glide. Plus the heavy weight. In my super gas car which was 2,600lbs same gear and tire i was coming through the trap at 7,300 rpm. When i say street very limited highway mostly in town driving. If i go auto it will have a t-brake. Even the bruno lenco has a t-brake.
Even if you went with a th400 or glide, high gear is 1:1. I think theres different gearsets for the glide but not sure.
You didnt meantion the type of FI your using. Turbo? Or SC?
There are calculators online, just do a google search. I'm on my phone otherwise I'd link one. I'm not sure what the bruno lenco is but lenco are not very street friendly. They do carry a bad *** status though.
calsdad
06-14-2023 11:07 PM
jscherbs
09-30-2015 07:54 AM
