TIME SLIP DATABASE
what whent wrong?
Old 09-22-2007, 06:49 PM
map0711's Avatar
what converter do you guys think i should get, i was thinking 2500 to 2800, what so bad about the tb spacer?
Old 09-22-2007, 06:59 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
It does not do any good and might be costing you. Drill and tap it for N20
Old 09-23-2007, 02:14 AM
99Silverado5.3's Avatar
Somethings up with your mph...I ran a 15.02@90.6X (2.22 60ft) with hypertech, no cats, custom cold air, and 3.42s open locker in my ex cab 2wd.
Old 09-23-2007, 11:45 AM
ZO6Ted's Avatar
Cam, weather maybe?
Old 09-23-2007, 11:56 AM
Banned
litreddevil's Avatar
the spacer is not hurting you at all i ran 12.59 with mine so you'll can get off the trip of the spacer hurting him,it is not hurting.
i would do a lsd soon and some drag radials then look at your times you will probably need close to a 2800 to 3000 stall for that cam.
Old 09-23-2007, 01:17 PM
OUT2WIN's Avatar
Maybe you would have gone 12.4X with out it
Old 09-23-2007, 04:12 PM
Banned
AND MAYBE I WOULD RUN A 13.86
Old 09-23-2007, 09:22 PM
map0711's Avatar
do you guys think i should get the tune looked at? whats an lsd? i was thinking on getting the bigger converter, lt's, locker, and some street radials then get it retuned, what do yall think i'll run with this setup?
Old 09-23-2007, 09:25 PM
map0711's Avatar
how can the spacer hurt me? what can it do to hurt the time? is it a restriction? or what,
if yall say i would be better with out it i'll remove it but i want to know why is it bad?
Old 09-23-2007, 09:34 PM
Mr. Obvious
nightrunner's Avatar
lsd = limited slip differential locker is not good for the street
yes the spacer is a restriction, it disrupts the smooth airflow.
Quick Reply: what whent wrong?
