wish me luck, time to step it up a little
#33
i got the latest drivers off their site.
i only spray for about .3sec so i dont think the nitrous is the problem. no egt gauge. i have the dual intank fuel pump set up. i am prety sure a fuel filter and taking the power wires to the alternator will help.
#36
Originally Posted by parish8
i think every run was against a 10sec lightning. the run where i ran a 10.3 was against the twin turbo one with a blow thru carb. that was a very clean set up. he had ran a pile of 10.24's that day and guess what. he did it again. his 10.24 took my 10.3. my rt was a little better than his and the diference at the end was .0116 with him in the lead. it was a fantastic race and a lot of fun.
Was nice to meet you. Would've liked to have talked to you more but you were always (at least when I saw you) surrounded by an entourage. You guys took some AWESOME pics! I love this one of my tailgate:
#37
i checked the voltage at the alternator and at the battery and it is exactly the same, even if i rev it up. i dont see any point in moving any wires around.
i swaped out the fuel filter. the new one i could blow thru easy. with the old one even after leting it dry out for a couple of hours was very dificult to blow thru. i cut it open and to me it looks like the filter paper is full of mud. not where the flutes are packed or anything but if you wipe a paper towel on the elemet it leaves what looks like mud on the paper towel. i hope this fixes the fuel problem
#39
Have you considered running higher gauge wire to the pumps. I would guess that the current wiring is 16 gauge - 12 or 10 gauge would make HUGE difference. Im sure the voltage is the same at the battery or at the alternator. You will have to measure voltage drop at the pumps. Typical voltage drop for wiring that long is 1-2 volts.
Good Luck - (You can always add a boost activated voltage booster)
#40
I agree what Jamesbond said esp. If you have stock wiring. I dont know how your Dual pumps are wired. But if you ran some , say 10ga back there, you should get "full" voltage back there.
Good Luck to ya man!!!!
I have a Fuel Filter sittin on my back seat i got to change..
